Announcements
Extrude To Objects
Extrude To Objects
gadesmet
Extrude To Objects
gadesmet
Community Visitor
Community Visitor
Hi, I was wondering if you can Extrude faces to connect to other objects? I know you can extrude to objects in Fusion and I use that feature A LOT in my workflow.
Grayson
10DSpace
@gadesmet
In Max there is "Bridge" (Editable Poly or Edit Poly rollout>Bridge) which will extrude polygons facing each other in the same object.
  If your objects are separate it is easy to to attach them first (Editable Poly Edit pOly> Edit Geometry>Attach) and then you can use bridge.   For obvious reasons, polygons cannot be immediately adjacent to each other for Bridge to work.   Here's a link to some simple quick videos:
https://www.google.com/search?q=3ds+amx+Bridge&oq=3ds+amx+Bridge&aqs=chrome..69i57j0i13i512l6j0i22i3...
