Exploding an imported layer from autocad.
Darwin33
Darwin33
I have imported a layer with several blocks from autocad. This blocks are all the same and were created in a different layer.  How can I explode those objects because they were created with array and I need to move them from this current postion.
Regards
rendermaster
are you referring to the layer or the object on that particular layers? explode command in 3ds max is for object grouped in 3ds max and is not applicable for objects grouped in other software, however, you can use the sub-object selection at modifying panel to detach or move a specific object you want
if you still want to you explode command in 3ds max, there's a plugin found in Autodesk app store names explode. I haven't used it, so I don't know yet its capabilities.
https://apps.autodesk.com/3DSMAX/en/Detail/Index?id=2091841125298582567&appLang=en&os=Win64
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
