Edges on selected object are invisible
I was unwrapping my object and when i switched to other object edges were not visible. They were only visible when i blindly select them. I tried display edged faces in the configure viewport. I also tried reseting max but nithing is working. It is happening only in this file.
miledrizk
Go to the shading label near the viewport's name, click the Per-View Preference,
Now, in the Per-View Preferences tab check the option Display Selected With Edged Faces.
Remember that this option is saved with your scene, so resetting Max will hot help
Since when you open your scene Max will use the saved setting.
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
