3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Double render image
5 REPLIES 5
2856 Views, 5 Replies
Double render image
Hi, During rendering I am getting double image - like on the screen. Does anyone know how to sort it ? Thank You in advance! 099.JPG
5 REPLIES 5
jon.bell
It looks as if you have a stereo camera (that is, true "3D") set up in V-Ray, so it's rendering left-eye/right-eye views.
Can you check your Camera settings and make sure this isn't on? Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
rendermaster
check if you have vray dome camera in the scene, delete it
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
ads_czechoj
I found one solved thread with the same issue. Maybe in your case this will work as well:
https://forums.autodesk.com/t5/3ds-max-forum/double-render-frame-with-v-ray/td-p/9170878
in reply to: egija.mangulsone
ads_czechoj
in reply to: ads_czechoj
@rendermaster is right: delete the vray dome.
topangala
Tenia el stereo activado en assets- camera. Una vez desactivado todo volvio a la normalidad.
