Create polygon from vertices
yellowcab
yellowcab
I would like to create a polygon from vertices. When I try to create the polygon it says illegal new face. Any help would be appreciated. Thanks.
Create polygon from verticesCreate polygon from vertices
10DSpace
@yellowcab
You will first have to delete the inner ring of polygons adjoining the square edges that you seem to be trying to create a polygon across.  There has to be an open edge along each side of the square that the 4 vertices form for you to be able to create a new polygon there.   Once you have the open edges by deleting the 4 polygons in the inner sleeve, you will be able to either  use Create to make a new polygon or use "Cap" at the border sub-object level on the new border that you will have made.   You could also "Bridge" across 2 opposite edges.
