Yes, it is case by case and with more experience you'll find it easier. You just extend a loop by cutting through a few more polys and run it to an edge or just bury that cut in a corner that's on a flat area where it won't matter. You really don't 'convert' it to a 4-sided poly, you add cuts so that it has 4 verts instead of 3. You do the same thing for poles (polys that have 5 or more verts), you cut them up to make them 4-sides. Again, it comes with experience how best to cut things up. There are some good videos on Youtube about it.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
