Compenetration in my models
Hello everyone, I would like to know why, the objects I put inside the project can be seen interpenetrated. is there a way to avoid this?
BenBisares
Autodesk Support
Autodesk Support
It looks like you're getting z-fighting issues probably due to the high value of your units. You can read more about it in the article below. I would first try using Near-clipping to fix this. Perform the following:
  • Left-click on the Viewport label, "Perspective" for example, and enable "Viewport Clipping"
  • If the Viewport drag the "Near Clip" slider up a tiny amount, usually a few pixels
  • Test and see if you still get the same effect. You know you went too far if parts of your object close to the camera start disappearing
Object(s) exhibits polygon z-fighting, moves erratically, and/or form becomes distorted
Ben Bisares
