its not a problem, it happens when you hide some elements in your poly ( element or polygon for example ) and forget your last selection in vertex level
even if you unhide the hidden parts in element or polygon level.
to fix this :
go to vertex level , and hit unhide all.
to fix this :
thanks for the solution! I had the same problem.
Nothing above worked for me, found what did on a forum, just sharing here for anybody in the future:
[from 3dTotalFoums - commented by user daniel1982]
"Very possibly, your problem is that the option "SHOW END RESULT" is turned on (that is the second icon on the bottom of the modifiers stack), but you dont have any other modifier on top of your editable poly."
