I know about F3 and F4, but usually when i used maya and 3ds max 2014, i could see edges when i select an object....now i cant. When i go into edge mode, i cant even see edges at all unless i blindly select them. This image i show has a box of 2 segments and i selected the middle edges....can only see what i selected in red.
Any help?
Solved by leen1999leena. Go to Solution.
Solved by Diffus3d. Go to Solution.
Solved by Steve_Curley. Go to Solution.
O M G! thank you soooo much! ive been trying to find this online for 5+ hours and noone had the answer! U are the best thanks!
I'm currently having the exact same problem. So frustrating! Did you figure out where this was in the 2017 version?
I also encountered this issue in 3DS Max 2017. Couldn't find the option in the preferences, but it seems to help if you select the following from within the viewport (see image in attachment) in the shading options (not on the [+] but the rightmost option [Default Shading] in my case)
Display Selected ==> Display Selected With Edged Faces
That's actually the same setting that was mentioned in the first solution, I guess they just changed the location in the menus.
Hope this helps! Bruno
Yes it is "Display selected with edged faces"
For 3DS MAX 2017 now it is under Pre-View Preference, (3rd option right to the plus sign)
I don't mean to necro a dead thread but this came up for me today and the posted fix didn't solve it for me. I was doing some work with soft selection and then I attached it to a part that didn't have soft selection enabled. Then my edges didn't show the selection in red. To fix the problem for me, I just had to check soft select on and then off and the problem resolved. Marking this as another solution.
Best Regards,
Alfred (AJ) DeFlaminis
I have a 2019 3dmax version I solved this problem by going to views menu in the top of 3d max window:
Views > show materials in view port as > override with fast shader.
Looks like there are a couple things in here that worked for people but aren't marked as solutions, I'm going to mark the latest 2 so folks like Laura have an easier time in the future.
Best Regards,
