Can I work on low poly models with these specs
This widget could not be displayed.
Hi , Im using 3ds max 2015 . My pc specs are attached. Im running on very little I assume resources, but I have a deep desire to just get working already on some models that are just adequate enough to fit into a video game(like PSP level character models etc. ?)
I just want to make it happen.
With these current specs is it possible for me to push a low res low quality but smooth workflow? I would like to know, suggestions, points, anything
Thank You
PROH
Hi. Max requires minimum 4Gb RAM (8Gb advised), so with memory below this you might not even be able to run Max at all.
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
These are the full System Requirements for Max 2015.
I would say you should add more RAM 2GB is not a lot these days.
