Booleans
Booleans
Booleans
I am trying to subtract an inner cone from a solid outer cone and cannot get it to work? Any suggestions would be great.
BenBisares
Autodesk Support
Autodesk Support
What's the end result? Nothing happens or does it look inverted?
Generally issues with Booleans are due to objects not being manifold (not "watertight"). You can check by using the "STL  Check" modifier.
Ben Bisares
leeminardi
Another approach for modeling the shape is to create a 2D line shape of half of a section cur of the "cone" and then use lathe to create the revolved shape.  I think this might yield a cleaner model with the advantage of being able to adjust the number of segments in the circumference of the shape.
lee.minardi
