Best way to cut shapes into objects
Hey everyone
I'm in the process of modelling some boots for my Character. The boots has a pattern around the top. I've attached a pic of exactly what I want and I'm just wondering the best way to go about it.
So far I've tried creating the chapes with splines. changing the thickness and applying turbo smooth then using bend to wrap it around but obviously the boot is a odd shape at the top and it doesnt wrap around correctly.
I tried cutting the shapes into the boot then extruding the shape and applying chamfer but this also mucks up and seriously messes with the geomatry.
I'm hoping theres a more simple solution that I havent though of yet.
Any help.
PROH
Hi. Since the pattern  is quite small and only extrudes very little, I would personally make the it with a bump or normal map + having it shown in the diffuse map as well.
Hope it helps.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Daf
^ Definitely the way to go.
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
