Array modifier with grouped objects
Dantetron
Message 1 of 8
Dantetron
Howdy.
Is there a simple solution to my problem seen in the screenshot below? I'm using the array modifier and it wants to use each inner object's individual transform properties instead of treating them like a group.
Unlike the other array tool found in the "extras" toolset. This is using Max 2023 though I tried it in Max 2024 with the same results.
Thanks!
Replies (7)
Message 2 of 8
Dantetron
Autodesk-
Do we know if this is a bug or if I'm just doing it wrong?
Thanks.
Message 3 of 8
wernienst
Try Total Dimension instead of the default Relative Offset.
Message 4 of 8
Dantetron
Thanks for the response.
All options (total dimension, relative offset, fill) have the same undesirable results. Below is 'relative dimension'...
It's an extremely easy problem to replicate.  Just take 3 spheres of varying sizes...
Group them and apply the 'array modifier' and you can see the modifier does not adhere to the group's orientation but the individual object's orientation...
Message 5 of 8
wernienst
Works as expected (tested in 2023 and 2024).
array-test3.jpgHave you accidently left the group open?
Then there is still the option of combining the objects to an EditablePoly.
Message 6 of 8
Dantetron
Thanks for the reply.
I did a super crappy job of illustrating my problem which I apologize for.
I think the biggest issue with grouped objects and the array modifier is individual rotation.
original
Below, I took 3 spheres and rotated them in different random orientations. Then grouped them and applied the array modifier.
As you can see, the objects want to go in the altered rotated axis direction, not the group's unaltered axis.
In this case, the example shown above is using the 'total dimension' distribution.
This time I attached my project file which I should have done to begin with.
It's a Max 2023 file.
Thanks for the help!
Message 7 of 8
wernienst
Ok, now I see the problem. Only solution I found is ungrouping the group, unselect everything (this is important!), reselect the objects, go to the Utilities tab and perform a Reset XForm before regrouping.
Message 8 of 8
Dantetron
EXACTLY what I was looking for.
Thanks so much for the solution.
