Aligning Jagged Edge
Part 1.jpgHi,
I am fairly new to modeling with max. I have created this shape, but want a straight edge all around. How do i achieve this? I Created it from using a box, then using turdosmooth. Then deleting polygons. Is there a better way?
Many Thanks in advance
Nick
kgokhangurbuz
Hello @Anonymous ;
You can achieve this by following these steps:
-select all the vertices at the end of this object, in your case, the jagged parts vertices
-go to modify > Editable Poly > Edit Geometry tab
-You'll find 3 buttons next to eachother, X,Y,Z.
-Click on the correct one corresponding to your axis to align all together in the same line
kind regards;
Thank You,
This is a great help.
