Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Anyone knows how to align these vertex to in a straight line with the circled vertexes? Image attached. Thank you
Unfortunately there is no command for this (Make Planar would move the other vertices).
Try this: in Edge mode, select the middle edges and remove (NOT delete!) them.
In Vertex mode, select the vertices and remove them, too.
The result:
You might recreate the removed edges with the Connect tool.
Hi, Thanks for your quick answer.
Issue will be more clear when you try to do same thing "in next step" of same object. Of course you can allways delete the geometry and create new to fit for your needs but i would assume there should be tool to do this simple task or some plugin to do this.. I hope you undestand what i meant by the "next step" by just doing the same thing over again next vertex in the line.. Its gonna take much more time to do this if you take these next steps into account unless its possible to align selected vertex by the other 2 vertex..
Can you tell if 3ds max also has a loop edge tool that could change the curvature of selected edges, for example, by degrees, etc.? Better measuring tools would also be nice additions..
Thanks again and have a nice day!
