A small right-click glitch.
This widget could not be displayed.
First - love the new 2019! But something I use very often is glitching out on me. When us use Edit poly->Edit polygons->Extrude (Settings) and try to bring Height to zero by clicking the lower arrow with the mouse left click... it visually does that but the numbers stay! (and you have to manually change the number for it to be zero) It's a tiny bit annoying but not something huge. Tho I am sure that it's not how it is supposed to work.
Great work anyway! As always, love and respect!
Replies (7)
don_3259
hi may be some glitch there try to install new update of september month may be its fixed...thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
My install is a single day fresh 😄 So it should be as updated as can be.
don_3259
Hi again it only works with option not when you do it manually with button so use only its given option.
thanks
Ali Sajjad
Hi again! This should clear things up.
don_3259
its same for me for me also i think its developer bug or new thing
Ali Sajjad
Bug was fixed in 2019.2
don_3259
hi yes thanks for telling i checked after update its working now.
Ali Sajjad
