11:31 PM
I run into the following problem with the 3ds Max 2017:
when I Import a .Step, if I have 3ds Max in mm the UVW Map Box is applied in inches, as a result, in order to have it appear in mm I have to set max in inches, import the .step and save the file.
At this point I open a new 3ds Max in mm and I merge the file previously saved in inches; this way when I apply the UVW Map Box it is correct.
