Announcements
Working Pivot -not- working for cloning (RESOLVED)
Message 1 of 1
I'm attempting to use Working Pivot, located under Hierarchy, in order to clone an object around the Working Pivot instead of the object pivot, but when I attempt to hold shift in order to duplicate the object using Working Pivot, the gizmo snaps back to the object pivot instead of the Working Pivot.
Does anyone know if this is an issue with Max 2017?
RESOLVED!!!:
There's a check box at the bottom of the Working Pivot panel title: Pin Working Pivot.
What's the point of this tool if not to auto Pin it after you've edited it?
Hope this helps someone.
Replies (0)
