WELD BUG
WELD BUG
WELD BUG
I attached two objects together. Then I selected the 2 vertexes and used the weld command. I used the target weld command it didn't merge. I pressed ctrl alt shift it didn't merge. Is there a bug in 2022?
jibijib
They need to be within the tolerances/distance - click the box next to weld, and set to maximum. Select the top element, turn on vertex snap and then snap move the object onto the other to avoid it stretching.
If you are only welding two vertices, then just 'collapse', this will merge the two or more vertices into one.
The problem is already here. Even if I press the box of the Weld command and set the value to the highest level, it does not weld.
