Viewport problems with WireFrame backface and Normal view brightness (screeshot)
Hi guys. Look at the screenshot. There are two weird things.
1) In the Wireframe view it doesn't display backface wireframe though I rotated the view a bit, just a few vertices appeared in the nose area. How to fix it?
2) In the Shaded Realistic view the mesh shines too much so the wireframe is not visible at all. How to make it softer? When I render it it's not so bright.
don_3259
hi kvv.dev there is option ignore backfacing uncheck that and for get rid of this brightness use dark color and after doing your topology then use desire color.
thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
I didn't find the ignore backfacing option. The only one I know is when you select vertices you can prevent selecting those in the back but it's not the option I need. I'm talking about displaying backfacing edges of the mesh, currently they are not displayed
don_3259
check the attached image in object properties there is option called backface call uncheck that so its no more for you
Ali Sajjad
Thanks, that works!
don_3259
welcome dear friend give kurdos if you like my help...thanks
Ali Sajjad
