Announcements
Vertice weights keep resetting when I change them.
Hi, something strange is happening with the edit envelope thing. When I select my vertices and go down to the Abs. Effect and turn it up or down, it doesn't save it and just resets to what it was when I click on another vertice. Not sure why.
Any help?
raiden_xavier
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thanks for sharing this oddity with the forums.
Without being able to see it my initial guess would be:
Skin > Advanced parameters > Reset Selected Verts
Can we get some screenshots or videos of what you are trying to do and what happens instead?
Look forward to hearing from you.
Excuse my lateness, but thanks for the response. Here is the link to the file. https://drive.google.com/file/d/1S5NJlmd_0W6-OeGl-boA1348EUp_jnhx/view?usp=sharing
If it appears for you the way I saved it, if you select any vertice on the left thigh and try to change it it will reset to its original effect for some reason. Thanks for your help.
