UV maps seemingly messing up when exporting to .obj
Message 1 of 14
I have a model in .max format and I wanted it to be exported to a more universal format (such as obj) so I could use it in Blender, the issue is that in 3DS Max the uv mapping seems fine,
but when exported the positioning of the texture seems to be messed up.
Replies (13)
Message 2 of 14
10DSpace
I suggest trying the .fbx format for export from max and import into Blender.  Generally, IMHO it is a better format for export and import across platforms.  Good luck.
Message 3 of 14
Unfortunately this seems to produce the same issue. But thank you for your reply.
Message 4 of 14
10DSpace
@Anonymous
And when you compare the UVW map from 3ds Max  from UVW Unwrap to the Blender imported version they appear to be identical?    Sometimes if the UV map in Max has some UV verts outside the 0,1 tile, they will still display properly in Max. Maybe this gets messed up in .fbx export?  Also, you get no errors on .fbx export from max?
Message 5 of 14
The confusing thing is that it seems to store the uv info in the skin? Since it is a rigged model.
I think this may be vital info in solving the issue
Message 6 of 14
10DSpace
No, as far as I know there is no way for UV info to be stored in the skin modifier.   The UVW Unwrap modifier should have been applied before the skin modifier and then collapsed.   Any time you place the Unwrap UVW modifier on the mesh, it will reveal the UVW map.  You simply do not have it in the modifier stack right now from your picture.
To figure out what happened I suggest the following:
1. Make a copy of your 3ds max file and work on that.
2. Pplace the Unwrap modifier right above the mesh and open the editor to see the UVW map.  If it looks good with an orderly layout of UVs and no overlapping UV verts/faces then close the editor.
3. Turn off the skin modifier in the stack by clicking the eyeball next to it.
4. Select the mesh and export it via .fbx  using Export selected.
5. Import the .fbx mesh into blender and see if this time the model texture seems to be placed properly.  If not, check the Blender UVs to see if they look the same as what you saw in Max.
Message 7 of 14
Here is the apparent UV map in 3ds max and then blender, looks like part of it isn't even on the map in blender and may be in the wrong position, the texturing on the model is definitely wrong.
EDIT:
I also got this error
looking at the blender image of the UV it looks like it expects the texture to be mirrored or something? (based on the teeth section)
Message 8 of 14
10DSpace
With the exception of the one UV island off on it's own in Blender, the UV islands in both max and blender correspond in position, although the Blender version has lost the correct aspect ratio (i.e., instead of a square like 2048 by 2048 it is a rectangle that  looks twice as tall as wide).   What is the aspect ratio of the actual texture map you are using?
I also wonder whether that UV island that is off on it's own and looks like a butterfly, is actually in the wrong UV tile in Max.  I could not find that same butterfly shape in the max UVW Unwrap that you sent so maybe it is in another UV tile that your view does not include.  To check this, go back into max and open the UV editor.  In the upper right hand corner there is a checkered icon that enables the option "Show the multi-tile in the dialogue", click on this to enable multi tile display.   Can you find the butterfly shaped uv island?
Regarding the error message, is your Unwrap UVW modifier above the skin modifier? it should be below it, just above the mesh.
Message 9 of 14
I moved the unwrap below it now, here is the screenshot of what was asked
Message 10 of 14
10DSpace
OK, now all you have to do is correct the UVW map in max and re-export to .fbx, this time enabling the skin modifier.  However, note that
 if you move any of the "good "uv islands in the u1v1 tile your texture map will be off.  So, to avoid this, check first to see what the errant uv islands correspond to in your mesh.  If it is not an important part of the mesh you might get away with scaling them down and dragging them to an unused part of the u1v1 tile being careful not to perturb any of the other uv islands.  It is critical that this all be done with the uvw unwrap modifier right above the mesh, but below the modifier stack.  Hope this works for you.
Message 11 of 14
I have no idea how to fix this, there is a texture I found that is a butterfly version that -seems- to fix most of it but then the eye is also off in terms of positioning for an unknown reason?
Despite the textures being shown to be lined up and correct the result given is nothing alike, is this not some sort of bug?
Message 12 of 14
I managed to solve the problem by just creating "butterfly" versions of the textures by duping them and flipping the duped part horizontally.
example
original
edit
basically it appears 3ds max was doing this mirroring on the original texture, but failed to transfer this over when it was being exported, so it was manually introduced.
Message 13 of 14
10DSpace
Glad you were able to solve the problem.
Message 14 of 14
Thank you for your help, I appreciate it 🙂
