Swift Loop Limitation
Hi, is what i am doing a limitation of swift loop? I have not been using max for too long but would have though adding edges was quite easy. To demonstrate my issue I have done the following;
1. Created a box standard primitive
2. Converted to editable poly
3. Extruded one side
Up to this point swift loop works as it should.
4. Chamfer 2 edges
This is where swift loop falls over, edges cannot be added over the entire geometry in x,y and z.
Image below may clarify better.
Thanks for any help.
I am using 3DSmax Design 2015
hi, swift loop works with quads only 😉
Cheers for that.
What would you say is the best way to add edges on non quads? I can't find a good way to do this.
Steve_Curley
Cut Tool, Quick Slice, select polys then use the Slice Plane, select edges and Connect them. Take your pick. Each has their uses - use whichever is most appropriate under specific circumstances. You may need to use a combination of them to get the desired result.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
great tool is also Paint Connect in the ribbon
Thanks both Smiley Happy
