Selecting curve axis
Darwin33
Darwin33
I have modelled a curve wall for an small church and now I need to select the axis. As far as I fillet the axis for rendering I think it will be better to make a section in the middle of the wall and then take that shape. Can guide me in the procedure. If I try to select axis within edit poly I found the axis formed by multiple small arcs and I have to select them one by one, what is tedious. IS there a way I can select all at once.
Define 'Axis' . Post an image perhaps, so i can get an understanding what you mean by 'now I need to select the axis'.
miledrizk
You're using the wrong term, these are edges, not the axis,
To select them all you need to go to Edge sub-object level and use Ctrl + A,
Or you can drag a rectangle around them
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
