Announcements
Select object in vilewport bug? 3ds max 2025
infoTP6WE
Message 1 of 10
infoTP6WE
When I want to select an object, I can almost always click an object behind it. It's like ignoring the faces of an object closer to the camera. The whole selection is completely random, but I usually succeed in wireframe mode, but only if I find it very difficult to find an edge that it lets me click and does not see part of an object behind it...
Version 2025, there were no such problems than before (2020-2024).
Replies (9)
Message 2 of 10
RobH2
That's something I see now and again too, then I don't see it for awhile. It might related to some other function that just hinders it temporarily. I know that didn't give you a solution.
Have you reported it officially using the links Hagen provides in the top of the main 3ds Max Forum? The more of us who report it the more likely it gets on a "defect" list to be looked at.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 3 of 10
MartinBeh
Something in MAXScript to try:
nitrousgraphicsmanager.HardwareHitTestEnabled=true
or the opposite
nitrousgraphicsmanager.HardwareHitTestEnabled=false
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 4 of 10
RobH2
That's a great little piece of code to keep in a "Handy Max Code" text document somewhere. Thanks Martin.
Rob Holmes
Message 5 of 10
infoTP6WE
amazing, it works the way it used to! thank you very much for your help!!
Message 6 of 10
MartinBeh
Glad to hear this is helpful.
Just keep in mind that there might be other side effects if using hardware hit testing or not, especially with regards to selecting non-mesh objects (cameras, helpers, lights etc.).
Message 7 of 10
pinguimcg
I appreciate the code. But this is a bizarre bug to be kept. Our productivity slowed down a lot because of this.
Is there a way max25 loads the "nitrousgraphicsmanager.HardwareHitTestEnabled=true" code by default? It resets everytime i start max
Tks
Message 8 of 10
MartinBeh
This is forum is mostly user-user and not so much an "Autodesk support" forum, so you need to use the official channels to contact support and provide feedback.
As mentioned before, there are downsides to always have hardware hit testing enabled, so maybe this is not the best idea - but yes, you can place the code in a startup script.
Message 9 of 10
thomasXQHH9
Observer
Observer
Confirming that this worked in max 2026. This needed to be run on a new install, so note to developers that this may be mistakenly disabled by default, causing a lot of headaches, and should be addressed.
Message 10 of 10
b_sodre
Community Visitor
Community Visitor
Amazing, thank you very much!
