Scripts/plugins for 3D printing
I'm currently looking to produce a 3D print of the City of Birmingham, Uk. The model is not in a state to print as a lot of the models need to be made solids. Does anyone know of any script or plugin that could automate this process. Doing it manually could take the rest of my working life so that's not an option.
Here's one that that I have found:
http://www.sycode.com/products/mesh_to_solid/
Henry
Assuming your models in question are polygonal geometry, isn't it possible to simply apply a shell modifier to all the objects at once? Shell should act the same as giving the objects "wall thickness", turning most non-manifold geo into "solids". If the models have open ends, then simply go into border mode, select all borders, and cap. Then select all, and apply a shell to all models at once. Not saying this will work in all cases, but it could work, depending on the structure of the models.
