ProBoolean and link and select doesnt work (3dsmax 2018) im desperated
Message 1 of 9
Hi
I have some issues with 3ds max 2018. With proBoolean and Select & Link.
It worked all before in the same project. im guessing i pressed on a wrong buttom or something?
I looked on forums for problems with proBoolean and tried, nothing worked. ( more polygons on both objects and + edit poly).
Select and Link worked on my biped before, now it doesnt... I know there is another way at animation tab but it cost to much time if i need to link multiple objects.
When i save my selected objects seperated as a max file and open in 3ds max 2019 its has the same issues.
If i close my 3ds max. and restart 3ds max without loading my current project. And test Proboolean on a simple box and cillinder, then it works al fine. Even my select and Link works on a biped.
My guess is wrong hotkey becaus the problem i have now is all saved in my current project.
Any pro's can help me out?
Sorry for my bad english!
Greetings
Floris
Replies (8)
Message 2 of 9
Check your selection filter. Make sure it`s set to 'All' or whatever type you want to pick in your scene.
Message 3 of 9
I checked my 3ds-max and the select option is on All, guess there is another problem.
Link & Select doesnt work anymore also. i have to go to the animation tab to add link.
Got any suggestions?
Thank you for answering.
grtz Floris
Message 4 of 9
Can you upload the file so that i can take a look?
Message 5 of 9
Here is a link to download my 3ds max file
I saved in Maxs 2017 and max 2018 versions
https://we.tl/t-bUFYXgKcZI
greetings
Floris
Message 6 of 9
Hello and sorry for the delay.
I took a look into your scene files, and the first thing i noticed was that they where infected by the infamous Maxscript-virus ALC.
Read about it here:
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Scene-...
Boolean operation and select-and-link are working just fine with your file. So this issues might be caused by the malicious script infecting your scene.
About select-and-link: Please note that once you applied a Link constraint to an object, it`s no longer affected by it`s parent object transform. Parent has to be specified in the Link constraint then.
Message 7 of 9
Thank you so much !!! it works fine now 😄
greetings
Floris
Message 8 of 9
Glad it worked out for you. Did you remove the 'infection'?
Message 9 of 9
Yes it worked, i downloaded the security tools of autodesk and it removed the infection 🙂
thank you for your help ! 🙂
greetings
Floris
