New to 3DS and using 3DS 2012 version 15.0. I’ve run across two problems.
One is I build a small uncomplicated model using an image on a image plane in the background to get proper proportions. For some unknown reason, the image from the image plane ended up on the model and I cannot figure out how to get rid of it.
Second problem relate to a part I made using the “line” tool. I made the spline using this tool, and extruded the shape a number of times to get the correct shape. I forgot to cap the object but did it later after “ProBoolean” the object a number of times. After I capped it , I find that the color of the object is coming up strange in render – very dark and smeared like and completely different than other objects colored with the same color. Can this be corrected? What did I do wrong?
Any help would be much appreciated.
