Announcements
Preventing vertices/faces from being selected through the mesh
t_smith5
t_smith5
Even when my mesh isn't see through and is solid, when I select vertices above others, the ones at the bottom will be selected as well. Is there any way of preventing this? Such as only getting Max to select the vertices that the camera can see?
No there isn`t really. However, 'Ignore Backfacing' can help, but it only occludes subobjects that are facing away from the POV.
leeminardi
You might try viewport clipping.
lee.minardi
t_smith5
Hmm...  I've tried both Ignore Backfacing and Viewport Clipping but I'm still having an issue. If I position the camera looking down and select vertices using the drag-select, then re-position the camera looking from the front, vertices within the eye socket are selected too.
This is why i said: 'Ignore Backfacing' can help, but not solve the problem. This option only prevents subobjects from being selected when their normals are facing away from you.The lower lid vertices/polygons are still facing your viewpoint, and that`s why they are still selected.
There is no solution to this. 3dsmax doesn`t have a selection type that occludes non-visible subobjects.
