Odd artifacting on geometry
jackgriffiths1998
jackgriffiths1998
Loaded an OBJ file into a scene and have come across this artifacting on some geometry and I don't know how to get rid of it. Any ideas? cheers.bandicam 2019-09-19 16-36-45-160.png
miledrizk
Select all vertices and use Weld with a very low value like 0.001,
Now select all the polygons and in the Smoothing Group rollout,
With the default value first, click the AutoSmooth,
You can with different values to see if anything change.
If it's still an Editable Mesh object try converting to an Editable Poly,
And also try the suggested above.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
jackgriffiths1998
Thanks for the reply! I tried this but unfortunately didn’t get rid of it completely, I’ve written the model off as broken, but thank you for the advice!
miledrizk
Try, from the Element sub-object level, selecting one element like the car's door,
And do what I suggested in my previous reply, maybe it can help more than doing it on the whole object.
miledrizk@gmail.com
