Announcements
Modelling paint glob?
I was wondering if anyone knew how to model a paint glob/swatch/anything remotely cream like?
kennyj
you didn't say which software?
In 3ds Max / Maya, for the first image you could create a simple Pill and then apply a melt / non-uniform scale.  Then apply a material for the first image.
The second and third images you could extrude along a path.  Make a spline in the back and forth pattern, then make a circle for the shape.  Extrude the circle along the path.  You could also make a pill or sphere, and modify it to deform to path using the back and forth spline.  Again, apply a material for the glossy / color.
Hope that helps!
Kenny
Oops my bad, I meant to add it but forgot. 3DS Max 2016.
