Announcements
Mirror around Working Pivot?
evan_yaoS46LP
evan_yaoS46LP
Is there a way to have the mirror modifier use the working pivot as the axis of symmetry instead of the object's pivot? (think Maya) Alternatively, is there a way to set the working pivot as the object's pivot?
RobH2
I can't figure out a direct way to use the working pivot as the axis of a  'Symmetry' modifier but you can set the 'Working Pivot' as the object's pivot.
1. Turn on snapping and snap the object's pivot to the spot, vertex, face, etc., using 'Affect Pivot Only' and snap it to where you want it and it will become the pivot. Click out of 'Hierarchy' to set the pivot.
2. Then select 'Edit Working Pivot' and hit 'Shift+A' and click the object. The working pivot will snap to the place you put the object's pivot.
3. Finally, click 'Use Working Pivot.'
4. All 'Symmetry' and it will use that Working Pivot.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
