Loop tool
Loop tool
Loop tool
Hi ALL
did they take out the loop tool that was in 3d max 2014
I can't find it in 2016
is it in 2015 I'm going to go back to 2015 can't use 2016 with cryengine yet.
thanks
Steve_Curley
Can you be a little more specific please? Which "loop tool" are you referring to?
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
If you're referring to selecting "edge loop" you can just double click the edge and it will select its loop (if you're not seeing the tool make sure you're working on an editable poly, not an editable mesh.
It`s still under Graphite-Modeling Ribbon->edge->Loops->(drop down)Loop tools.
