Announcements
how to make an object flat in 3Ds max?
I want to make this object flat but without deforming any of the measurements. How can I do this?
ShaunBrettig7993
1. Ensure object is a poly.
2. Set selection mode to Polygon.
3. Select all of the polys you want flattened.
4. In the Edit Geometry rollout towards the middle you will see Make Planar button, use any of the X, Y and Z buttons on the side to flatten in that axis.
Regards
Thanks so much 😉
