How to insert images on a plane im 3d max 2018?
Message 1 of 9
Replies (8)
Message 2 of 9
Have you tried just dragging the image file from its location and straight onto the object, or onto a material in the material editor?
Message 3 of 9
PROH
Hi. You need to load the image into a material (the diffuse slot), and then you can apply the material to the object.
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Message 4 of 9
Daf
Have you tried the "Show Material In Viewport button?" - can't  tell from screenshot.
https://www.google.com/search?q=3ds+max+show+material+in+viewport
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
Message 5 of 9
How to find a diffuse slot?
Message 6 of 9
PROH
Hi. See the attached picture and/or check out the help files (press F1).
Hope it helps
3dsMax 4.2 to 2018
Message 7 of 9
Hey. I have a newer version of 3d max (2018). Such buttons are missing.2loCuKjiHF.png5YTGr85cI6.png
Message 8 of 9
PROH
No it's not. I showed a "Standard" material, and you show a "Physical" material. In a Physical material the "Diffuse" is called "Base Color".
I'll strongly advise you to read up on materials in the help files 🙂
Hope it helps
3dsMax 4.2 to 2018
Message 9 of 9
StephenMF
There is a good "tag" about this on scriptspot.
I have used this for a long time
http://www.scriptspot.com/3ds-max/scripts/drag-drop-reference-images
http://www.scriptspot.com/3ds-max/scripts/tags/reference
Enjoy.
Stephen
