How to delete / remove useless edge?
Sorry for noob question
Im new, I just started!
So I've created some windows , but I want to remove them.
I used "Bridge" tool to fill the hole
and not I dont know how to remove this remaining edges
When I press delete it removes the whole face.
10DSpace
@Anonymous
Select the edges you want to remove and use bacKspace key the Shortcut) or select "Remove" in the editable poly rollout.  Remove does what you want while delete as you have seen is more destructive to surrounding area.  Hope this helps.
10DSpace
@Anonymous
FYI, There is also a circumstance in which you want to remove edges connecting 2 other edges and in that case, the backspace key shortcut will remove the edges but not their vertices.  If you want to remove both the edges and their vertices, then use Ctrl + Backspace.
