Announcements
How to create edges and vertices on editable poly?
Here's the thing, i want to get a plane with extrusions and insert a circle I will extrude as well.
If I do the plane, everything's ok and I get this result:
Now here's the problem:
- I create a new scene with a plane
- I create a circle (8 segments)
- I attach both elements
To get a correct topology, I'd like to add vertices and edges but it doesn't work. I tried with cut tool but the edge doesn't stop where I want and if I try to delete (or remove) the edge I don't need, it deletes the entire edge.
Questions:
1. How to add vertices on the circle?
2. How to create edges between plane and circle?
Thank's.
Here's what I have but there are triangle and n-poly. How can I switch them to quads to get a correct topoloy?
Any help?
