How to change wireframe color of NOT selected objects?
brunogf13
brunogf13
Hello. Just started to use MAx. Wanted to know if there is a way of changing the Wireframe color (when pressing F3/F4)
I know there is a way to change this when a object is selected, but I wanted to know if we can change the default color of black, when the object is not selected.
To be more precise, when you press F4 you turn on the "Edge Faces" mode, and by default it's black for all my objects, regardless of them being different colors. I noticed in some tutorials that these Edge faces colors are closer to the color of the object itself, which looks better and also useful if you press F3 to turn On "Wireframe" and you can differentiate between the different objects on the screen, instead of seeing all in black.
Many Thanks!
brunogf13
Oh, by the way, I'm using Max 2020
