- Mute
- Permalink
- Report
Morning,,
Suppose i have Sliced an Object Horizontally so i have two objects Shares the Same Lower and Upper Ends Edges...
They should be Perfectly 100% Fit... ok for anyhow i have Rotated or Moved one Without changing the SCALE...
and now i want to fit both back together...
i tried Align and also changed Pivot Z to Max of Lower Object and Min of Upper Object, because i know how Pivot works... but the Problem is once they're two object each one has his own Individual Pivot Center Point and its Different Center from both... anyway i guess u guys got my Point...
I want to Put the Object on it Place back again on the Main object...
i even tried to take Shapes from the Border Edges of the main object and Align the Other object to it... its still not Perfect......
is there a Way to Perfectly [Fit/Align/Place] BACK something's [Edges] Over something Else [Edges]...Even after Moving it to any Other Hights or even rotated it....?
