Floor generator doesn't work properly
sohadelghoneimy1993
sohadelghoneimy1993
Good day,
I'm experiencing an issue with Floor generator, The tiles' connections act strangely as shown in the attached images below.
Floor Generator V.2
a0120a50-7c3b-4813-bef8-0f49d41b22e4.jfif
9352556c-edef-4be8-a638-2c7d85759080.jfif
jbclerc
check "variation per board" if values are different than zero -> max rotation/min rotation".
RobH2
If it only happens in one or two spots can you put an ‘Edit Poly’ on it and just ‘Target Weld’ the verts to the correct spot? It might be a fast way to fix it and move on until you find a better solution.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
