Edit Poly Shift + LMC to select multiple edges not working in Max 2023
pmcreative
Message 1 of 1
pmcreative
In Max 2021 this works.
1. In a front view create a spline star shape (this can be any shape, it just needs to be closed).
2.  Convert it to a edit poly.
3. Go into edge mode.
4. Hold shift and select an outside edge so it highlights red and move you move, still holding shift and multiply edges are selected.
5. Click the left mouse button to choose the amount of joined edges you want.
A real time saver selection method.
Now try this in Max 2023.  This doesn't work. This has to work exactly as described for a particular modelling method I use. Can anyone get this to work?
Replies (0)
