Conformed Decal on Curved Surface is Folded Rather than Curved - 3ds Max
schaferb24
schaferb24
I've created a plane, created a standard material (legacy), and used a bitmap of the label as the diffuse color. I then assigned the material to the plane, conformed it, added a shell, and it creates this series of rectangles rather than a singular curved label. I have facets set to 100x100, and I've tried subdividing both the fire extinguisher and the label. I also tried smoothing (and TurboSmooth) on both assets. So far nothing has resolved this issue, any help would be appreciated.
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
schaferb24
I would like to include this image, taken in performance mode
MartinBeh
To me this looks like the actual polygons (without smoothing) of the fire extinguisher are too low.
Conform does not consider the visual-only smoothing - it will place all vertices directly onto the actual surface (as can be seen in "Surface" viewport mode).
Attached is a .max (for 3ds Max 2026) file that illustrates this phenomenon.
Solution: Increase the mesh density of your fire extinguisher; a Relax modifier on your "label" mesh might also be of help.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
schaferb24
Turns out all I needed was to Quadify followed by a Turbosmooth! I had no idea that Quadify was a feature (I've stuck to Inventor for a long while), and this helped tremendously. I will say that my model, which was imported directly from an Inventor assembly and kept as a body, did have some weird spaghettification once I used the Turbosmooth after the Quadify, but this was fixed by separating it from the parent assembly, so only the body received the modifiers. I will experiment with the fifth solution, as it seems to be the most efficient workflow. Thank you very much!FireExtinguisherT2.png
schaferb24
Turns out I needed to Quadify, and my count was way too low. Thank you! I didn't know that it was different visually. I didn't know the body was so low-poly.
