Cannot select layers by click and drag
sachong233
sachong233
When i wan't to select multiple layers i can only do so by click the layer one by one ,it's seems something wrong but i don't how can to fix it ,i search this question on Google but failed to found any useful results .捕获.PNG
miledrizk
To select multiple, click on the top element, then press Shift on the keyboard and select
The last element, now all elements in between will be selected in addition to the two selected items.
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Daf
You appear to be talking about items in a layer,rather than selecting actual layers. Regardless of which you should be able to select multiple items either by using Shift-1st/Last, as miledrizk mentioned, or by pressing Ctrl for separate non sequential items. If this is not working then there is a problem somewhere.
Daf
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
sachong233
I have found in some old version ,3ds Max seems can select layer by click and drag ,but when i want to do this in 2020 version i can only move them instead of select .Shift select seems not the same things .
sachong233
I'm really tired to find out the answers.Go to sleep .
