Announcements
Backface cull for editable splines
Hey
I'm using drawings imported from AutoCAD as references for modelling a building. So all the views and sections are placed around the floor plan.
when I use planes with textures I can turn on backface cull on them so from whichever view I'm looking the plande which is turned back to me is invisible and I can draw according to the reference "on the other side" of the floor plan.
Is there a way to do something similar with editable splines? Backface cull doesn't work on splined unfortunately. Maybe there is some helper\technical material?
I also though about using some kind of clipping like in camera but I don't know how to do it for regular views (left, right , etc. )
RobH2
I don't believe what you are thinking about is possible. 'Backface Cull' works because a polygon has a normal vector. If the vector is towards the camera it is visible, of not, it's invisible (if culling is enabled).
Splines don't have normals. They are just lines connected to points with x,y,x coordinates in space. A spline is just a mathematical representation of a connecting line between two points. There is not front or back or normal. It's just a line with endpoints.
You can use 'Viewport Clipping' in a viewport to limit what's visible and it will work on any kind of element but it's just clipping the z-depth of the view. It's not smart, it's kind of like depth of field except it 'clips.'
So, I don't believe you can cull splines the way you are describing.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
domo.spaji
It is working same as other mesh objects.
Whatever you do to see it in view it become a mesh with faces, normals... (like enable in viewport)
If you want to disable "wireframe" from back side on it in shaded view,  assign some mesh-turning modifier (like mesh select, UVW map...), set mod. to "Off in renderer" and obj. to backface cool.
That's for closed, non-overlaping splines, for others don't need backface cool - those will disappear.
Thanks. I did it with backface cull.
Thanks for hint. Will check it out.
