Autogrid Doesn't work properly in 3dsmax 2025, what happened??
m.ayed002
Message 1 of 8
m.ayed002
I noticed that Autogrid doesn't work properly when in Orthographic mode in 3dsmax 2025, there was no such problem in previous versions....
It only works fine in Perspective mode, in orthographic it doesnt project properly... It's frustrating, I mostly use orthographic mode and I use autogrid alot!
Replies (7)
Message 2 of 8
MartinBeh
Just tried it in a fresh scene and it works as expected for me. What else is different for you?
Also: what exactly do you mean when you say "doesn't work properly"?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 3 of 8
m.ayed002
It's better to show you
Message 4 of 8
MartinBeh
OK, I see. So Autogrid sometimes makes "precision errors" and does not align itself properly at the visual boundaries of objects - would that be a suitable summary?
Message 5 of 8
m.ayed002
yes, exactly
Message 6 of 8
MartinBeh
Hm. I cannot produce this issue, it works very precisely for me in iso view, around the visible edges... pixel-perfect actually.
Maybe a graphics driver issue?
Message 7 of 8
m.ayed002
I checked drivers and windows are updated, I'll try installing 3dsmax on another computer
Did you try it with splines? It works perfectly with other objects but not with splines
Message 8 of 8
MartinBeh
I did test it by creating multiple Rectangle shapes onto a box in front of a plane - very similar to what you showed in the video.
