Message 1 of 10
I am using 3ds max 2024.2 and I am seeing constant issues with edge dot ring. When I select one edge, click dot ring, the selection skips an edge and messes up the entire operation. This is bad because the only way around it is to manually select the dot ring, which can be time consuming.. Is there an update I may be missing, please help!
