While most may not feel the way that I do, it seems that the viewport focus point could use an enhancement that would certainly benefit my workflow. Currently, the viewport pivot works by anchoring to an invisible point that is pre-set by a certain distance from the viewport camera that can be moved by panning (alt+mmb) / (ctrl+mmb). The pivot, ofcourse works wonders when zooming out and selecting an object (relying on the pivotal point of the object) or pivoting the average point of your selection. It becomes problematic for me when I am working "up-close" to hammer out very fine detail and then I need to pivot the working area after dropping my selection. Many might suggest to change workflow and they may be right however, adjusting workflow often means working around limitations which I believe this is.
My idea is that there be a means (preferably a customizable hotkey + ui toggle button) to toggle and lock a visual representation of the viewport camera pivot point. So, there's three features in this idea.
As always, thank you Audodesk & the community for all that you do.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
