Smart Extrude Subtraction function
Smart Extrude should be able to perform all the functions of Boolean operations. Add a subtraction function to Smart Extrude. When you press Shift + Alt, the selected geometry only subtracts the intersected geometry in the extrusion area. The geometry outside the intersection is deleted.
Example in the picture
6 Comments
In 3ds Max 2022.2 you can perform the action you have described using the Shift + LMB (Drag) operation of Smart Extrude
hwoRX6FJ
It's great, but still sometimes it doesn't work. And unfortunately it doesn't work at all on planes.
anybody else can confirm this ?
Yeah I can confirm it doesn't really work on planes. And on non planar objects it also doesnt work when the object  to extrude on negative its a planar object (like negative extruding only a cylinder cap like in example above)
Please log as a bug, not as an ideas request
@logan_foster_adsk @as this been addressed  with the 2022.3 update ?
