seperate isolation
seperate isolation
having separate viewports to show the scene is great but being able to separately isolate objects from each viewport would be very helpful to keep checking on objects in huge scenes while working on specific isolated ones from other viewports.
2 Comments
shawnolson
Than you for your idea. I wanted to let you know that you can already do what you want to accomplish inside the current Slate Material Editor. You can always drag values used from one material into slots on another material. And for comparing the values, all you need to do is enable the Show All Additional Parameters option for a material (which you can access via right-clicking a material). See attached screen shots.
peshang
Thank you @shawnolson  for the reply, even though my question was about viewport isolation of objects not showing parameters of the a material in material editor.
(i guess this answer should be moved to the other post i did on 3ds max, here is the link:
https://forums.autodesk.com/t5/3ds-max-ideas/opening-multiple-material-parameter-editor/idi-p/960506...
