Show only
Search instead for
I would like a way of clearing missing plugins from a scene. It would be good if max could select assets in a scene dependent on the missing plugin so that it can be manually fixed (example: show all materials with missing plugins).
There have been numerous times where I tried opening up a project file, just to get the error(s) that a plugin is missing, or when I try to save a project file without using any plugins that I have, there is no way for me to ensure that my project file is 100% vanilla 3ds Max without any additional plugins that I have have installed.
We have made some updates to the Scene converter coming your way, that should help with this. You can remove standins from the scene with the converter, and it is accessible from maxscript. It should help clean things up for you.
Sounds cool, I can't wait to see what you guys have been working on. (3ds Max 2017 was a disappointment [in terms of stability/usability], 3ds Max 2018 was better, but I know it still has areas that it can be improved.)
you can pretty much chose what you want to delete and want to keep. Items that have dependencies will get auto selected, there is nothing you can do with that... if a DLL goes, so does everything else. Hope you find it useful
Hi, I just implemented this tool in 3dmax 2020 with vray 4.x on a file created in v.2018 with vray 3.x and the file is closed does not allow me to open it, there should be a way that 3dmax when it finds something without solution allows rescue some of that file 😞
